| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | |
| Date Logged & Current Version | July 2020 12.03.00.17 |
The following is displayed when opening a model in AutoPIPE:
Error
E31-37: Material type not recognized. Re-enter
OK
How to fix this issue?
One known issue to cause this message was after incorporating a new customized material library the message would appear when trying to selecting a new materials added to the library. on the Pipe Properties Grids / Dialog.
Confirm the customize MATL name on the SPEC table is 100% exactly as shown in the MATL table. Any deviation would cause this error message to appear. After making any adjustments in the SRC file, recompile the library, and place into the Bentley %PROGRAMDATA% folder with the other LIB files, and restart AutoPIPE.
