| Version(s): | ALL |
| Area: | Opening |
| Date Logged & Current Version | June 2018 40.06.00.07 |
Can I open older Microprotol models in the new version of AutoPIPE Vessel?
Yes, at this point the file format has not changed. Therefor you can use the same model in both applications. However the file format may change with a new release in the future, so be certain with each new version for file compatibility.
