| Version(s): | Connect |
| Area: | Install |
Date Logged & Current Version | June 2020 41.05.00.008 |
Note:
1. CLOSE ALL APPLICATIONS before starting this installation process.
2. Contact your IT department to be sure that there is no user restrictions for installing software on your computer system. If so, request IT assistance.
The Following procedures assumes:
- Account has already been set up with Bentley Licensing with company employees already added to User management and with the correct User Entitlements.
- Person installing the application is logged into the computer with full Administration rights.
- Installing on Windows OS mentioned in README file.
- Prefer that the application is not installed over a network connection; suggest that the *.EXE file is on the users system before starting the installation.
- All previous versions of AutoPIPE Vessel have been removed from the computer prior to this installation. Another words, completely uninstall all previous versions of AutoPIPE Vessel before proceeding.
Installation
See Video for typical default installation procedure:
Note: select
from the video to enlarge to full screen mode.
AutoPIPE Vessel application has now been installed.
Licensing
See Video for typical default licensing procedure:
CONTINUE with Licensing AutoPIPE Vessel
Bentley AutoPIPE Vessel
Bentley Select Services Technical Support webpage:
