| Version(s): | V8i & Connect |
| Area: | Install |
| Date Logged & Current Version | July 2016 40.07.00.007 |
Note:
1. CLOSE ALL APPLICATIONS before starting this installation process.
2. Contact your IT department to be sure that there is no user restrictions for installing software on your computer system. If so, request IT assistance.
The Following procedures assumes:
1. Navigate to the downloaded file: apvs4xxxxxen.exe
2. Double click on on the *.EXE to start the installation process.
The following are typical screen shots and responses for a default installation:
Press Next button
Read the EULA agreement enable the check box and then press Install button:
Press Yes button
It may take a few moments for the application to verify minimum requirements are met. If not, the missing windows applications are now being downloaded and installed
Press Next button
Update information on as needed on the 3 lines provided, and press Next button
Press Next button
Press Install button
It may take a few moments for the application to unzip and install the application.
Press Next button
A new dialog may appear off to the side, CONNECTION Client Sign in. You can choose to Sign in now or later this will have no bearing on the installation of the program.
Continue with the installation. Readme file will then appear
Press Close button
CONTINUE with Licensing AutoPIPE Vessel
Bentley Select Services Technical Support webpage:
