| Version(s): | V8i & Connect |
| Area: | Install |
| Date Logged & Current Version | December 2016 40.03.00.08 |
Note:
1. CLOSE ALL APPLICATIONS before starting this installation process.
2. Contact your IT department to be sure that there is no user restrictions for installing software on your computer system. If so, request IT assistance.
The Following procedures assumes:
1. Navigate to the downloaded file: apvs4xxxxxen.exe
2. Double click on on the *.EXE to start the installation process.
The following are typical screen shots and responses for a default installation:
Note: If Net 4.5.1 or higher has not been installed on this computer the following will appear:
Note: Reboot the computer Now, select "Force Restart", otherwise an error will occur. Upon restarting the computer the first image above should have appears, otherwise start the installation all over by double clicking the download *.EXE file again. Follow the same steps as above to this point and continue below. Since the Net framework was installed the first go around, the Net 4 installation will be skipped this time through.
Click here if the following dialog was displayed:
Continue with the following steps.
Note: A new dialog may appear off to the side, CONNECTION Client Sign in. You can choose to Sign in now or later this will have no bearing on the installation of the program. See Dialog to the right
Continue with the installation. .
Note: Read the EULA agreement:
Note: Following 2 screen shots may not be displayed for AutoPIPE Vessel CONNECT 40.01.00.08
CONTINUE with Licensing AutoPIPE Vessel
Bentley Select Services Technical Support webpage:
