| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Software |
| Date Logged & Current Version | May 2019 12.01.00.09 |
How to check CONNECTION Client for updated software?
Use the following instructions:
2. Select the Gear button in the top right corner and select Preference.
3. A dialog will appear, choose Updates from the top. This will show your current settings. Suggest mirroring the following settings here:
4. Regardless of current setting, press Check Now button. IF an update was available, a smaller dialog would have appeared with the number of updates found. Otherwise it would indicate 0 updates found.
Press OK to continue.
5. Press Close button on CONNECTION Client Preferences dialog and go back to the main application screen.
6. Install Update - click here
Manually download and install Connection Client
