Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Corrected Version: TBD
Description:
Add ability to define an imposed displacements at the current node point for each transitional and rotational axis direction applied for analysis by selecting a load case(s). Command cannot be issued if applied to soil, anchor, or other support type node point(s).
