| Product(s): | AutoPIPE | ||
| Version(s): | All | ||
| Area: | Installation | ||
| Date Logged & Current Version | Mar. 2015 09.06.01.10 |
User with Administration right to the computer is attempting to install AutoPIPE, while going through the license agreements and about 3 Nexts screens the installation suddenly fails.
After the installation abort, the following was found in the error log file:
Could not create system restore point, error: 0x80070005...
Why is this happening and how to Avoid it?
This is a permissions issue.
AutoPIPE should be installed by person who has full permissions to the %ProgramData% folder. Contact your IT department and ask that they confirm / update your computer permissions for Everyone, System, Administrators, and User as needed. In addition, add Administrators group to ACL and granted them full control may help your issue.:
Specifically, check the ACLs of "%ProgramData%\Package Cache" and make sure,
After permissions have been changed, try to right click on the installer file and select Run as Administrator
Errors that occur when Installing / Uninstalling
