AutoPIPE is a desktop program itself and it is only the licensing and CONNECT Advisor that require an internet connection.
However, SES licensing uses the HTTPS protocol over port 443 for all communication. Because licensing uses standard protocols and ports, no firewall configuration should not be required unless specific sites are allowed or blocked. Please refer to “Which domains does the CONNECTION Client access?” in the following FAQ in this case.
