Q. Available features in AutoPIPE Vessel v.41.03 based on license type selected
Product(s):AutoPIPE Vessel
Version(s):ALL
Area:License
Date Logged
& Current Version
Oct 2019
41.03.00.009
Problem:
What features / licensing choices are available in AutoPIPE Vessel v.41.03?
AutoPIPE Vessel 41.03..xx.xx had the following 2 types of licenses available:
1. Standard
2. Enterprise
The following table lists features that are available when selecting a given license (give attention to item super script notation where indicated, details at the bottom) :
Feature
AutoPIPE
Vessel
Standard
AutoPIPE
Vessel
Enterprise
ASME VIII (US design code) 1
PD5500 (British design code) 1
CODAP (French design code) 1
AD-Merlbätter (German design code) 1
EN 13445 (European design code) 1
GOST (Russian design code) 1
GB (Chinese design code) 1
Pressure Vessel Design & Analysis
Shell and Tube Heat Exchanger Design & Analysis
Storage Tank (API 650) Design & Analysis
Air Cooler (API 661) Design & Analysis
Boiler (NFE) Design & Analysis
Chimney Design & Analysis
Microstation - 2D, 3D (dgn file creation) 2
AutoCAD - 2D, 3D (dwg file creation) 2
SolidWorks – 3D ONLY (sldprt, sldasm file creation) 2
Local Load 3
Expansion Joint and Bellows Design (including TEMA 9th FEA method) 3
Tubesheet layout (no tubesheet calculations, only layout design) 3
Anchor Base 3
Shell / Head / Cone / Flange 3
Beam design 3
U Bend 3
Flat plate with stay bolts 3
Cost Estimate
Fatigue Analysis
Motion Analysis
Blast Analysis
Wind, Vortex shedding, Seismic Calculations
Support and Lifting Accessories Calculations
Compress file import (build 7510)
AutoPIPE Nozzle Load Import
Import of Aspentech and HTRI files
Export/Import to PDS
IFC File Export
PXF File Import/Export
Platform, Ladders Modeling, External Loads
External Loads, Structural and Piping Clips, Packing, Trays, Coil, Stiffeners
(1) Choice of one code (per user's choice and as mentioned in license agreement) is included in the license for Vessel. However, the user may select more than one code in which case he/she will be charged separately for the code that is NOT covered in the license. Enterprise license includes ALL the design codes.
(2) CAD export capability limited only to the type of equipment that can be modeled (based on the license type - Vessel or Enterprise).
Example: With Vessel license enabled, user cannot export a Shell and Tube Heat Exchanger model to drawings. User must have a Vessel Enterprise edition license enabled to export a Shell and Tube Heat Exchanger model to drawings.
(3) Individual component modeling/calculations can be performed instead of full equipment modeling and design.
Additional info:
1. Only those features with a check mark next to them will be available with the indicated license type selected.
2. For ELS accounts only, these accounts will be reset / invoiced on their renewal dates for any usage of Add-on codes.
3. If a particular piping code or edition is not available please log a Bentley Service Request asking that it be added.
Release Notes
License Configuration - What do you see
Subscription Entitlement Service
AutoPIPE Vessel
