License Configuration - What do you see (v.41.03 to 41.00)
Each time AutoPIPE Vessel is started, the application will display the AutoPIPE Vessel Licensing splash screen as shown below, unless the "Show licensing on startup" (lower left corner) check-box is disabled.
Select a single radio button
Depending on your licenses available in the License Management Tool, select the appropriate AutoPIPE Vessel Edition radio button.
Demo:
After installation, AutoPIPE Vessel will run in Demo Mode until it is properly authorized. To ensure compliance with the terms of your purchase agreement, a security system is utilized. All software authorization for new Bentley products is handled by the Bentley Security Manager.
When Demo mode is selected the program will NOT allow the following commands:
- Save the model
- Use Calculate Strength
- Generate Drawings
- Perform Cost Estimation
- Add-on codes
These features are only available in the full Vessel or Vessel Enterprise licensed version.
Again, users can create any type of vessels in the UI but they cannot be saved, In addition, users can open an existing model in the UI, but you cannot run Strength Calculation.
Vessel Standard:
Only a limited amount of the program features can be used, see link here for features available / not available with this level of licensing enabled.
In addition, per contract agreement, only one vessel Add-on code is provided with this level of licensing. Additional Add-on codes can be included to the contract, talk to Bentley salesperson for details and pricing.
Indicated Add On codes
Only those codes with a check box enabled next to them will be available in this session of using the program
Note: User should only enable the check box next to the Add-on code mentioned on their contract. Enabling any other Add-on code that is not indicated on their contract will constitute over-usage and user will be invoiced accordingly. These Check-boxes cannot be locked out, Users must self regulate add-on usage not indicated on the contract. Many users like this ability to only be charged for usage instead of having to add another full time add-on code to the contract. This feature saves many users a lot of money and is very convenient to use as needed.
Vessel Enterprise:
All program features and all Add-on design codes will be available with this level of licensing, see link here for completely list.
Notes:
1. Grayed out text
Meaning - item cannot be used at this time because additional requirements have not fulfilled.
       Example: "Vessel Standard " radio button is unchecked and all add-on code text shows as being grayed out.
#2: Cannot enable Radio button
 This may be directly related to your licensing settings.
Step #1: Confirm that you are signed into CONNECTION Client.
Step #2: Confirm licensing settings, open BLT (Bentley Licensing Tool) to confirm that licensing is correctly set. Contact your company's assigned Bentley On-site admin for User Entitlements.
Also Suggest to Visit the Licensing page for more information.
If item is missing from listing above, contact your Bentley on-site Admin to confirm "no check out restrictions" are in place for your product or contact Bentley License department to confirm possible missing products on contract.
License dialog for v.40.06.00.007 and lower
Subscription Entitlement Service
AutoPIPE Vessel
