OPM中螺栓长度计算规则
螺栓长度计算,首先计算基准长度,方法如下:
对夹式法兰计算方法:
Machine Bolt_Length = COMP_LEN + [(Gasket_Thickness) x 2] + [(Flange_Thickness) x 2] + Nut_length + BOLT_XCESS
Stud Bolt_Length = COMP_LEN + [(Gasket_Thickness) x 2] + [(Flange_Thickness) x 2] + [(Nut_length) x 2] + [(BOLT_XCESS) x 2]
普通法兰
Machine Bolt_Length = (Gasket_Thickness) + [(Flange_Thickness) x 2] + Nut_length + BOLT_XCESS
Stud Bolt_Length = (Gasket_Thickness) + [(Flange_Thickness) x 2] + [(Nut_length) x 2] + [(BOLT_XCESS) x 2]
之后根据数据库中螺栓基本长度BOLT_LEN + 步进长度BOLT_INC 的整数倍得到实际螺栓长度
举例:
如根据阀门长度以及法兰垫片螺母等长度累加后得到需要螺栓长度为131.2mm,
之后根据螺栓基本长度76.2 + 步进长度6.4 x 9 = 133.8mm
最后得到螺栓长度为133.8mm。
