如下MVBA代码能将当前文件的颜色表以RGB值的形式输出到指定的D:\ColorTableOutput.txt文件中。
Sub OutputColorTable()
On Error GoTo FILEOPEN_ERROR
Open "D:\ColorTableOutput.txt" For Output As #1
Dim ct As ColorTable
Dim clr As Long, red As Long, green As Long, blue As Long
Set ct = ActiveDesignFile.ExtractColorTable
For i = 0 To 254
clr = ct.GetColorAtIndex(i): red = clr Mod &H100
clr = clr \ &H100: green = clr Mod &H100
clr = clr \ &H100: blue = clr Mod &H100
Print #1, "Color " & i & " - RGB " & red & "," & green & "," & blue
Next
clr = ct.BackColor: red = clr Mod &H100
Print #1, "Color 255 - RGB " & red & "," & green & "," & blue
Close #1
MsgBox "ColorTable exported to D:\ColorTableOutput.txt !"
Exit Sub
FILEOPEN_ERROR:
MsgBox "File D:\ColorTableOutput.txt is in use"
End Sub
