| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT | ||
| Area: | Install | ||
| Date Logged & Current Version | Feb 2017 11.00.00.22 |
How Do I Install Bentley AutoPIPE CONNECT 11.00.00.22?.
1. This procedure assumes that Select Server XM has been install and configured, If not please contact the license group to assist you.
2. User currently logged into the computer must have full Administration rights.
3. Suggest that AutoPIPE CONNECT is installed by accepting all the default settings.
a. Prefer that the application is not installed over a network connection; suggest that the EXE file is on the users system before starting the installation.
b. If you have already installed other AutoPIPE versions, using add/remove programs uninstall:
i. all previous versions of AutoPIPE
ii. " PCF to NTL translator
iii. " ADLPipe to NTL translator
iv. " Bentley STRAIT
c. Navigate to the EXE file download using the download procedure.
d. Double click on the "ap11000022en.exe" to start the installation process.
Note: Be patient while the application is installing as it is checking to verify programs already installed, verifying drive space, etc.. there may be periods when it appears nothing is happening. Give the system time. In the event the installation stops a warning / error will be presented. Just follow the prompts and be patient. Highly recommended that all applications are closed during the installation process. On average it will take 6-8 min to install everything.
Press Next button:
Enable check-box and then press the Next button:
Enable all the check -boxes as needed, (default all), and press Next button:
Press Install button:
Press Yes button
Be patient as the program is now installing the application:
Note: If the following screen below appears, the user must restart the computer before the installation can be completed, click "Restart Now Button". Otherwise press "Restart Later" button to close the installation process, close all applications that are running, and then manually restart the computer to complete AutoPIPE installation.
After restarting, the application will automatically continue installing the application.
Again Be patient as the program completes the installation:
Click Finish button:
After clicking Finish button the AutoPIPE readme file will be displayed, click here for a WIKI posting of this file:
Finished, AutoPIPE has now been installed, continue:
If the program will not install based on the instructions above, please log a Bentley Service Request mentioning this page and include a copy of the Error log mentioned above
Install any Dependencies that were also downloaded (typically double click on the EXE files that were downloaded, i.e OpenPLANT Isometric Manager, ProjectWise, etc..).
Detailed installation procedures for these other applications can be found on other WIKI pages or readme files.
Before starting AutoPIPE, continue to STEP #3: Set-Up Licensing
Download, Install, and License AutoPIPE CONNECT 11.00.xx.xx and higher
