| Product | Bentley AutoPIPE CONNECT |
| Version | v11.02.00.10 |
| Language | English Polish |
| Date Posted |
English - Jan 2018 |
| Platforms |
Microsoft Windows 7 Professional or higher (with Service Pack 1) |
| .NET Framework |
3.5 SP1 |
Description:
Bentley AutoPIPE CONNECT Edition v11 (v11.02.00.10) - English
Bentley AutoPIPE CONNECT Edition is a stand-alone, engineering application for the calculation of piping stresses, fatigue stresses, fluid transient, bowing or thermal transient analysis, flange or pipe support design, and equipment nozzle loading analysis under static and dynamic loading conditions. In addition to 30+ piping codes, AutoPIPE incorporates ASME, JSME, British Standard, European, API, NEMA, ANSI, ASCE, AISC, UBC, GOST and WRC guidelines and design limits to provide a comprehensive analysis of the entire system.
This new release provides new features, critical code updates, and enhanced product interoperability. This is a product generation update for AutoPIPE CONNECT (v11.01.00.23) which includes several bug fixes plus the following new features:
The following outline identifies new features and enhancements in the AutoPIPE CONNECT Edition version 11.2.0.
Note:
1. Readme file contains limited amount of information about errors / enhancements, only QA&R members have access to detailed Error Reports
2. Total updates from last version (v.11.02.00.08)
New Enhancements: 0
Fixed Defects: 17
See procedure here
| AutoPIPE Preview Handler | 01.01.04 |
| Bentley ADLPipe to AutoPIPE Translator | 01.00.00.22 |
| Bentley AutoPIPE Batch File Generator | 01.00.00.03 |
| Bentley AutoPIPE CONNECT v11 |
11.02.00.10 |
| Bentley AutoPIPE CONNECT v11 Setup |
11.02.00.10 |
| Bentley AutoPIPE Nozzle V8i | 08.11.08.32 |
| Bentley PCF to AutoPIPE Translator | 01.00.00.69 |
| Bentley STRAIT to AutoPIPE Translator | 06.00.00.15 |
| Connection Client | 10.00.07.30 |
| OPIM (OpenPlant Isometric Manager) | 08.11.11.285 |
Program Name: AutoPIPE CONNECT Edition
Revision or Version Number: v11.02.00.10
The above computer program has been validated by both manual and automated testing procedures as part of a comprehensive product test plan consisting of more than 700 verification and validation test cases. Software quality metrics are defined against a quality standard established by existing and historical commercial versions of the program. Bentley Systems, Inc. maintains a quality assurance program t hat controls the life cycle activities of this computer program for the design of nuclear safety related piping in compliance with ASME NQA-1-2008/ 2009a, 10 CFR Part 50 Appendix B, and 10 CFR Part 21 quality standards. Test plans and validation data are on file at Bentley's Walnut Creek, California, USA office.
Support for this computer program is described in Bentley SELECT Program Agreement and includes 24/7 telephone, email, and web based support along with free upgrades and updates as they become available.
See copy of Software Validation Certificate by starting AutoPIPE, select Help Ribbon, Software Validation certificate icon.
AutoPIPE CONNECT Release Notes (10.00.xx.xx - higher)
How do I download, install, and license AutoPIPE?
