What do I need to integrate Deliverables Management with a project in my existing ProjectWise Datasource?
You will need to install the PWDM Connector for ProjectWise Explorer. See the here for details on the latest updates
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0030397
What versions of ProjectWise Design Integration are supported? (requirements listed are PWDM Update 2 10.00.02.213)
ProjectWise Deliverables Management connector for ProjectWise Explorer supports the following versions of ProjectWise Explorer:
Additional Requirements If Using ProjectWise Explorer V8i (SELECTseries 4)
In order to associate a project in ProjectWise Explorer, the version of the ProjectWise server that ProjectWise Explorer is connected to must be one of the following:
What ports need to be opened on my firewall?
Addresses and ports that have to be made accessible through firewall in order to be able to use PWDM:
 https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0030377
In addition, see the following regarding the firewall requirements for the CONNECTION Client (required when using PWDM Integrated with PW Explorer)
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0018790
Is there a server side install?
No, nothing needs to be installed on your ProjectWise Integration Server
How do I associate a ProjectWise Design Integration Work Area with a CONNECTED ProjectWise Project?
In a ProjectWise Explorer Work Area, the properties window will have a ProjectWise project tab. Here you can associate/change/remove a ProjectWise project.
