Getting Started with ProjectWise Web Connections
ProjectWise Web lets you access files and create and modify connections to repositories where files are stored. Before you can access ProjectWise Web, you must first sign in and open your project. Once you are signed in, you need to connect to a repository to download or review the files in the repository.
