To sign in to ProjectWise Web Connections, go to the CONNECT Portal, enter your account information, and select Sign In.
To access ProjectWise Web Connections you need to have a Bentley CONNECT account. For more information about registering a CONNECT account, see the Bentley CONNECT page.
