Once you have signed into the CONNECT Portal using your Bentley CONNECT account, select your project from the Recent Projects tile, or select the View More Projects icon to see a list of all available projects.
When you select your project, the Project Portal opens. From the ProjectWise 365 Services pane, click the ProjectWise Web Connections tile.
From this page, you can access the contents of your connected ProjectWise Work Areas. You can create and manage connections to repositories and view the contents of those repositories. For more information, see the Work Area Access topic.
