2 - Editing or Deleting a Connection
Editing a Connection
From the Manage Connections page, select the Edit  icon. The Edit Connection dialog displays. You can edit the Name or the Description. Click Update to save your edits.
From the Manage Connections page, select the Delete  icon. The Delete Connection dialog displays. If you are sure you want to delete the connection, click Delete and the Connection is deleted and no longer displays in the Manage Connections list.
