The following configuration is required for both ProjectWise Web and ProjectWise Web View cloud services.
Starting with ProjectWise CONNECT Edition Update 3.3, the ProjectWise Plug-in for WSG is a separate download, and is no longer delivered with ProjectWise Server Setups.
Bentley Web Services Gateway 02.06.08.09 is also available as a separate download. This is the same version that was delivered with ProjectWise CONNECT Edition Update 3.2. If you already have this version of WSG, then all you need to do is get the latest version of the plug-in.
Note: Normally, the version of the plug-in must match the version of ProjectWise Explorer. For example, ProjectWise Plug-in for WSG CONNECT Edition Update 3.3 requires ProjectWise Explorer CONNECT Edition Update 3.3. However, ProjectWise Plug-in for WSG CONNECT Edition Update 3.4 requires ProjectWise Explorer CONNECT Edition Update 3.3 and does not work with or support ProjectWise Explorer CONNECT Edition Update 3.4.|
For this service |
Enter this URL |
Required for |
ProjectWise Web |
ProjectWise Web | |
ProjectWise Web View |
ProjectWise Web View | |
Integration with Microsoft Teams |
https://connect-projectwiseteamshost.bentley.com
ProjectWise Web
Integration with Microsoft Office for the web |
PDF Markup Service |
ProjectWise Web | |
Old work area connections (those created in old ProjectWise Web / ProjectWise Share) |
ProjectWise Web | |
ProjectWise 365 |
ProjectWise 365 |
Here are diagrams of how access is controlled: Here’s the link to the PowerPoint version with animations.
Only cloud service administrators can add a connection to each datasource you want to make available to users in ProjectWise Web.
Open ProjectWise Web and click the Manage Connections button. In the Create New Connection window, configure the following:
This setting does not display at all if BentIey IMS single sign-on is not enabled in the datasource, or if Bentley IMS single sign-on is enabled but there are no Bentley IMS accounts in the datasource. If the setting does not display, or if you turn the setting off, you will see a message that says, This type of connection is not federated and will prevent online editing of Microsoft Office documents.
or
User Name and Password - The User Name and Password fields are only used if the Use Bentley IMS Authentication setting is turned off or does not display at all. If either of these is true, then you must enter the user name and password of a ProjectWise user who has access to this work area which will be used to create the connection. When configuring a connection that does not use Bentley IMS authentication, any user who tries to open this work area in ProjectWise Web will be prompted to enter their user name and password, which can either be a logical account or a Windows-based account.
The Work Area list displays all of the work areas in the datasource that the user who is creating the connection has access to, and for which a connection does not already exist.
This option is off by default. If you do not turn it on now, you can turn it on later by editing the work area connection.
When this option is off, you can still manually add your work area participants to the ProjectWise project by going to the Project Team Management portal (https://connect-rbacportal.bentley.com/) of your project.
User permissions are set in ProjectWise Explorer. If a user has access to a datasource, then they will see the datasource when they log into ProjectWise Web.
Want to see what you can do with ProjectWise Web? Visit our online Help file or Communities Page.
Latest versions of:
*Preferred browsers
Again, if you need more detailed instructions on setting up ProjectWise Web, see your ProjectWise Web documentation or ProjectWise Administrator Help.
