About ProjectWise Web Cloud Service
ProjectWise Web Connections lets you and your team collaborate on projects by securely sharing files and documents using a web browser. You can access ProjectWise Work Areas from your Design Integration common data environment. See what's new in PW Web
NOTICE: Existing ON-premises PW Web User’s must update their CORS configuration to include https://connect-projectwisewac.bentley.com to use the new UI. Otherwise, click the link at the bottom left of screen to return to the previous UI to access your connections.
