| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT | ||
| Area: | Install | ||
| Date Logged & Current Version | Oct. 2015 10.00.00.10 |
| Product | Bentley AutoPIPE CONNECT |
| Version | v10.01.00.05 |
| Language | English |
| Date Posted | March 21, 2016 |
| Platforms |
Microsoft Windows 7 Professional or higher |
Description:
Bentley AutoPIPE CONNECT Edition (v10.01.00.05) - English
Bentley AutoPIPE CONNECT Edition is a stand-alone, engineering application for the calculation of piping stresses, fatigue stresses, fluid transient, bowing or thermal transient analysis, flange or pipe support design, and equipment nozzle loading analysis under static and dynamic loading conditions. In addition to 30+ piping codes, AutoPIPE incorporates ASME, JSME, British Standard, European, API, NEMA, ANSI, ASCE, AISC, UBC, GOST and WRC guidelines and design limits to provide a comprehensive analysis of the entire system.
This new release provides new features, critical code updates, and enhanced product interoperability. This is a product generation update for AutoPIPE CONNECT (v10.00.00.10) which includes several bug fixes plus the following new features:
Fixes: xxx Enhancements and Errors were completed
The following outline identifies new features and enhancements in the AutoPIPE CONNECT Edition version 10.1.0.
PXF Import: Increase length of PXF material name to 50 characters to improve interoperability with plant design programs i.e. OpenPlant Modeler and AutoPLANT
Model consistency check added to warn user when Beam Modulus = 0.00
Model consistency check added to warn user when zero values are set for fields in Pipe Properties dialog
CONNECT overview documentation is now more visible in the program and Help content
Help content has been update to better explain the current velocity extrapolation
Technology Previews - Provide users preliminary access to features currently in development but not yet ready for production. These features are provided at no additional charge to promote awareness of a feature or technology to be deployed in a future release. Users are encouraged to provide feedback and suggestions. Please log a Service Request naming which Technology Preview feature you like to enable in AutoPIPE.
See the DETAILED Readme file
Note: the read me file contains limited amount of data about errors / enhancements, only QA&R members have access to detailed Error Reports
See procedure for Installing AutoPIPE CONNECT 10.01.00.04
| AutoPIPE Preview Handler | 01.01.04 |
| Bentley AutoPIPE CONNECT | 10.01.00.05 |
| Bentley AutoPIPE CONNECT Setup | 10.01.00.05 |
| Bentley AutoPIPE Nozzle V8i |
08.11.08.26 |
| Bentley STRAIT to AutoPIPE Translator |
06.00.00.15 |
| Bentley PCF to AutoPIPE Translator | 01.00.00.43 |
| Bentley ADLPipe to AutoPIPE Translator | 01.00.00.21 |
| Bentley AutoPIPE Batch File Generator | 01.00.00.01 |
| Connection Client | 10.00.04.17 |
| OPIM (Open Plant Isometric Manager) | 08.11.09.574 |
AutoPIPE CONNECT Release Notes (10.00.xx.xx - higher)
How do I download, install, and license AutoPIPE?
