| Version(s): | All | ||
| Area: | Licensing | ||
How to run AutoPIPE as an ADMINISTRATOR, while logged in as a general user?
Using the following procedure:
Start the computer and log in as a normal user, or closed all versions of AutoPIPE before continuing.
LocatedĀ the AutoPIPE program icons in the Stat menu or desktop used to start the program.
For each Icon found, perform the following:
Using the mouse, hover overtop the icon
Press the right mouse button, and select "Properties"
Under Compatibility tab, check box in front of "Run this program as an administrator", checked ONĀ or enabled.
Press OK button.
Start the program.
Activation of Client Side Products and Registry Basics
