| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | |
| Date Logged & Current Version | Feb. 2019 12.00.00.14 |
How to find where that command is located within AutoPIPE?
What drop down or ribbon has that command been relocated too?
AutopIPE's development team has created a really cool feature, Binoculars , to help users locate a command within the numerous locations of the program.
By pressing the binoculars image located in the upper Right corner of the application screen, one can easily search for a command and find it's location fairly quickly:
Example #1: search for all commands that contain Beam:
Easily see the exact locations of all the commands. Not to mention that you can make custom toolbars to arrange icon commands as you like to work.
Example #2: where is the command to convert Bend to Node?
answer: press on the binoculars and type in convert
Also, consider referring to the following Supplemental Documentation available in AutoPIPE
a. Mapping AutoPIPE v11 Ribbon Commands to AutoPIPE v10 Menu Commands
b. AutoPIPE Quick Reference Card
Another Great resource is the Bentley Learn Server on demand video.
AutoPIPE Insider Skills CONNECT Edition - Special Interest Group
2015-12 AutoPIPE SIG - AutoPIPE CONNECT Edition
- AutoPIPE Ribbon GUI
