Start AutoPIPE, after the application Opens select Help> Tutorial.
Note: these videos are only available on AutoPIPE 10.01.00.08 and lower, because AutoPIPE CONNECT 11.00.xx and higher has a new interface called CONNECT Advisor and new listing of videos.
Creating a New Model
| Create a New System | Insert a Valve | Rotate and Pan | Renumber Points |
| Insert an Anchor | Windowed Zoom | Build a Branch from a Tee | Copy and Paste |
| Insert Bends | Insert a Flange | Convert a Run Point Junction to a Bend | Scale, Move, and Stretch |
| Insert a Run | Set New Pressure and Temperature | Edit Controls | Scale, Move, and Stretch |
| Insert a Reducer | Insert a Tee | Insert Intermediate Run Points | Select Point to Add Anchors |
| Insert a Support |
Modifying Properties
Make a Copy of the Tutorial Model | Modify Pressure and Temperature Loads | Review Point Properties | Select Range (Input Grids) |
| Select Range by Pipe Identifier | Graphically Review Pressure and Temperature Loads | Modify Pipe ID (Input Grids) | Modify Pressure and Temperature (Input Grids) |
| Modify a Pipe Identifier |
Loads, Analysis, and Results
| Insert Concentrated Load | Define a Static Analysis | Display Load Combinations | Design Change |
| Assign Thermal Displacements | Perform a Static Analysis | User Defined Load Combinations | |
| Assign Static Earthquake Loads | Graphic Review of Code Stresses | Interactive Review of Displacements |
Output Report
| Output Report |
Creating and Connecting Segments
| Open an AutoPLANT PXF Model | Convert a Run Point to a Tee | Create a New Disconnected Segment | BEND_8 |
| Review AutoPLANT Data | Add Nozzle Flexibility | Connect to Another Segment | BEND_8 |
Viewing Options
| Model View Options |
Creating and Inserting a Frame Model
| Create a Frame Model | Solid Model Frame View | Insert an AutoPIPE Model | |
| Add Anchors to a Frame | Insert Multiple Run Points | Connect a Frame to Pipe |
Analysis and Results
| Perform a Static Analysis | Review Interactive Displacement Results | Apply Result Filter Criteria | Rotating Equipment Compliance |
| Define Combination Options | Review Displacement Results (Input Grids) | Select Combinations | Review Code Stress Results |
| Review Code Stress Results (Input Grids) |
NEW User Guide - TIPs - FAQ - RSS Newsfeed
