03. Questions on Load Combinations dialog in AutoPIPE Nozzle
From the Load tab of the program select the Combinations button and the following dialog with additional tabs will appear:
Questions:
1. When should the "Include Pressure thrust in GR, Hy case" be used?
Load Tab - AutoPIPE Nozzle
