| Product(s): | AutoPIPE |
| Version(s): | 2004, XM, V8i, CONNECT; |
| Date Logged & Current Version | June. 2016 10.01.00.09 |
The following appears when trying to start AutoPIPE Nozzle:
System Error
Bad file name or number
OK
APNOZZLE
Run-time error '76'
Path not found
OK
Why and how to avoid?
The issue appears during setting up user profile when program tried to create "Bentley> AutoPIPE Nozzle" directory in "appdata>roaming" folder which is typically located on the users computer but in this case was located on a network drive. Again, in this case, user's IT department stored all profiling information at server instead of local computer.
This issue has been logged under the following and to be fixed in a future version of the application:
TFS-D492254: Program failed to run when user roaming profile is located at network drive
Option #1: Request that IT create a user profile in the %appdata% folder that allows cashing with the network folder.
Option #2: Revert back to AutoPIPE Nozzle 08.011.08.22 until the next version of the program is released.
09. Warnings, Errors, Crashed, Confirm Messages
