AutoPIPE has powerful features to insert additional node points between nodes or to actually insert new pipe lengths that automatically offset all down stream piping. In addition, AutoPIPE will automatically calculate the spacing when splitting a pipe run into multiple subsections. See video below for detailed instructions:
Note: select  from the bottom right corner of the video to enlarge to full screen mode.
