| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
| Date Logged & Current Version | April. 2017 11.00.00.22 |
How to modify multiple items fairly quickly in AutoPIPE?
There are typically 2 methods with which to modify components in AutoPIPE: 1. Individual dialog screens or 2. Input Grids
Both methods have their advantages and disadvantages.
Able to see all a components fields in a easy to read dialog with out having to scroll around like in a grid
Example: Pipe Properties dialog
Grid tabs group similar items together
Each tab has an Excel like feel with some Excel like commands making changes to multiple items fairly easy and quick
Able to order columns in sequential order by double clicking column headings
Make selection of items in model easier
Able to open individual dialogs directly from grid by double clicking 1st cell in row to the left.
etc...
Example: Pipe Properties Input grid
Short video, techniques on making modifications to components using the Input Grids.
Note: select from the bottom right corner of the video to enlarge to full screen mode.
Short video, techniques on making modifications to multiple Thermal Anchor Movements using the Input Grids.
See AutoPIPE help for complete details on grids.
How Do I ..... in AutoPIPE: Table of contents
