| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | How do I... |
| Date Logged & Current Version | Jan. 2018 11.02.00.10 |
2 different methods of changing temperature / pressure in an AutoPIPE model;
1. Operating Press / Temp dialog
2. Press / Temp / PipeID tab on input grids
See video here:
Note: select from the bottom right corner of the video to enlarge to full screen mode.
Both methods can be fast and accurate with the grids having a slight advantage in making minute adjustments with out having to first create a selection set as needed by the Operating Press / Temp dialog procedure.
See Bentley Learn server for contact AutoPIPE trainer more powerful techniques while using the input grids and different methods of selecting components in AutoPIPE.
How Do I ..... in AutoPIPE: Table of contents
