| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Import |
| Date Logged & Current Version | May 2020 12.03.00.17 |
What units are used for and how is the Bend Radius calculated when importing a PCF file into AutoPIPE?
General format of a BEND card found in a typical PCF file:
BENDEND-POINT 4650647.2720 1906894.4236 183607.2198 4.0000 BWEND-POINT 4650691.9363 1906894.4857 183715.7182 4.0000 BWCENTRE-POINT 4650692.0749 1906894.4858 183652.2187SKEY BEBWFABRICATION-ITEMANGLE 4500BEND-RADIUS 6.0355PIPING-SPEC E36TRACING-SPEC COMPONENT-ATTRIBUTE1 BOMCOLUMN_Material_COMPONENT-ATTRIBUTE2 BOMCOLUMN_SCHClass_STDWEIGHT 4.5CONTINUATION
PCF Translator will always use the units specified by the variable “UNITS-CO-ORDS” to be applied to a bend radius value. The “UNITS-CO-ORDS” can be found at the start of the file (typically line #3)
ISOGEN-FILES ISOCONFIG.FLS
UNITS-BORE INCH
UNITS-CO-ORDS MM
UNITS-WEIGHT KGS
UNITS-BOLT-DIA INCH
UNITS-BOLT-LENGTH MM
PIPELINE-REFERENCE 60-001-16"-36-1
In this example, Bend radius would be set to 6.0355 MM.
Again, AutoPIPE will use the PCF variable BEND-RADIUS value when available. However if BEND-RADIUS variable is missing from a bend card, then the PCF Translator will calculate the radius using the following:
Once the angle “a” is calculated then PCF Translator calculate the radius (r) using right angle triangle
PCF Translator FAQ & troubleshooting
