| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Load Case |
| Date Logged & Current Version | June 2020 12.03.00.17 |
Is it possible to change the gravity axis from y+ to y-?
One user has a piping system where it is showing upside down in the software since the gravity direction is in the y- and there are only y+ & z+ vertical axis selections available in the program
At this time, June 2020, no AutoPIPE does not have a feature to change the gravity direction. Only workaround is to rotate your model accordingly.
