| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Load case | ||
| Date Logged & Current Version | Apr. 2016 10.01.00.05 |
Can the individual loads from pipe properties (i.e. total Cladding weight, weight of pipe alone, weight of contents alone, etc...) be automatically calculate / reported in AutoPIPE?
This information is already tabulated in the "Center of Gravity" sub report. From the Model Listing Report dialog include the "Center of Gravity" sub report as indicated below:
Example of report
Otherwise, run multiple analysis or analysis sets turning On / Off different program features / settings, examples:
Static Analysis Set dialog:
Pipe properties
"Gravity" - AutoPIPE Load Case
