| Product(s): | AutoPIPE Nozzle |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Import |
| Date Logged & Current Version | Oct. 2016 08.11.08.26 |
Why are the import loads from AutoPIPE different in AutoPIPE Nozzle?
example: Given the following piping arrangement -
Notice that the load case Gr has different values, why?
How to avoid?
Both programs are correct
Let us be sure of the piping orientation. Looking at the top view one can clearly see that the piping (ex. A00 - A01) is not on a global axis but is skewed off axis:
Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Bentley AutoPIPE> Command Reference> File Commands> Export> Nozzle Loads to AutoPIPE Nozzle> read this section and then press on the "PXF Export Restraints" hyperlink. This will display:
Providing details on the file structure. See Code 8140 to 8143 for imported loads into AutoPIPE Nozzle. Also, open the model PXF file to review the values being exported:
If one created a Forces and Moments Restraint sub-report or Reference sub-report using the local option setting in AutoPIPE it would clearly show the local forces and moments at the Anchor (ex. A00) that was exported to AutoPIPE Nozzle. :
Note:
1. Restraint Reaction sub-report does not provide local forces and moments. They only display Global values.
2. Anchors are not listed on the Support sub-report in AutoPIPE. Only Support Types from the Support dialog are listed in the Support sub-report.
