| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Note Message |
| Date Logged & Current Version | May. 2020 12.03.00.17 |
The following note message appears in AutoPIPE:
Note
N734-200: Cannot display all point data due to dialog size limits
OK
Why and how to avoid it?
This is nothing more than a message to the user that dialog is too small to display all of the data. Best to select the node point and print out a complete model input listing using the report feature "Limit reports to highlighted points"
Example Steps to repeat:
1. Open a model
2. At a run node point insert segment Line number and 6 supports.
3. Press F3, the dialog above will appear.
Again this is to let the user know that not all data can be presented on this dialog due to limited space.
