| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Note |
| Date Logged & Current Version | May 2020 12.03.00.17 |
The following appears when importing / opening a model in AutoPIPE:
Note
N22-22: Option only available in Advanced version
OK
why and how to avoid it?
This is a note message and not an error, just a message to inform the user of important information. In this case, by performing an action in AutoPIPE the specific command is only available in a higher edition that contains more features than the one currently being used.
Example: If your License is configured to AutoPIPE and you are trying to insert Soil properties the above dialog would be displayed.
Why?
Answer, have a look at AutoPIPE help for chart of features available by the different editions of AutoPIPE (Standard, Advance, Nuclear). If the command being executed is not available in the current edition of the program selected, than the dialog above will appear.
Contact your Bentley Sales person to request adding the correct version of AutoPIPE, based on features required, to your account.
