This video will show you how to access ProjectWise Explorer Work Area from ProjectWise Web.
From the left pane of ProjectWise Web Connections, you can access the Work Area connections you have created. To edit or remove a connection, or create a new connection, click the Manage Connections button at the bottom of the left pane.
When you select a connection from the left pane, after you log in, the repository displays the files and folders which it contains.
