| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Import |
| Date Logged & Current Version | April 2020 12.03.00.17 |
How to filter out small bore piping from being translated into an AutoPIPE model?
Example: Model is composed of 2 different pipe diameters; 4" and 8". How to filter out the 4" pipe so only 8" pipe is imported.
Use the PCF translator's filter command "Ignore OD <"
Question: If 4 inch pipe and smaller is to be filtered out, what pipe size should be be entered on the "Ignore OD <" command line?
4", 4.5", or other?
Answer: Correct 4.5!!!
Let us see, set "Ignore OD <" = 4.00 inches, what happens?
Why? because the Nominal size is 4" but the PIPE OD was found to be 4.5" inches therefore, the small bore pipe is imported
Now set "Ignore OD <" = 4.5 inches, what happens?
Why? because the Nominal size is 4" and PIPE OD = 4.5" inches therefore, the small bore pipe was not imported
