| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Calculation |
| Date Logged & Current Version | April. 2018 11.03.00.08 |
Why are the results for Creep Rupt = 0.00, Blank, or not printed in the output report for En13480 piping code in AutoPIPE?
The creep value in the grids was set to 0.00. Without the creep defined, this Creep Rupt combination (ex. Sus+T1) will not be printed.
After adding some value great than zero e.g. 200 N/mm2 would start printing the load combination.
EN13480 Piping Code Calculation Issues
