Q. Is SES Licensing software network aware?
Question:
Is the software network aware? If it is, indicate the following impact:
a. Total number of TCP/UDP sessions used on the client.
b. How many total sessions are passed through the internet:
c. Concurrently on average?
d. Peak?
e. How much internet bandwidth is used on average and peak?
Answer:
Yes, the software utilizes Internet-based services to activate and provide optional services. For licensing purposes, we estimate 900 KB per hour when running idle per the following CONNECTION Client FAQ. The CONNECT Advisor, an optional contextual help system included with some Bentley software (ex. AutoPIPE), initially downloads a few megabytes of data to populate a newsfeed when initially starting but does not consume additional bandwidth unless used as mentioned in the following CONNECT Advisor FAQ.
