| Product(s): | ProjectWise Server V8i | ||
| Version(s): | 08.11.05.37 | ||
| Area: | General | ||
ProjectWise list of services and folders to exclude from Virus scan
ProjectWise list of services and folders to exclude from Virus scan for the software listed below.
1. PW version: 08.11.05.37
2. Bentley products are the box.
a. Logging service
b. USS - ProjectWise User Synchronization Service V8i
c. OFW - ProjectWise Orchestration Framework Service V8i
d. Integration - ProjectWise Integration Server V8i
3. Windows Server 2003 (32-bit) Version 5.2 Build 3790
Note the list below assumes the default install locations.
Bentley Files are located under
C:\Program Files\Bentley
File will also be accessed from these locations
Where ever the storage area is if on the box.
User profile for the user running the OF service / dmskrnl service
C:\Documents and Settings\All Users\Application Data\Bentley
C:\Documents and Settings\All Users\Application Data\Microsoft\Crypto
C:\WINDOWS\system32\drivers\etc\protocol
C:\WINDOWS\system32\drivers\etc\services
C:\WINDOWS\WindowsShell.Manifest
We load the following system DLL's / assemblies
C:\Program Files\Common Files\System\Ole DB\msdatl3.dll
C:\Program Files\Common Files\System\Ole DB\oledb32.dll
C:\Program Files\Common Files\System\Ole DB\oledb32r.dll
C:\Program Files\Common Files\System\Ole DB\sqloledb.dll
C:\WINDOWS\assembly\GAC_32\Bentley.Orchestration\1.0.0.0__4bf6c96a266e58d4\Bentley.Orchestration.dll
C:\WINDOWS\assembly\GAC_32\mscorlib\2.0.0.0__b77a5c561934e089\mscorlib.dll
C:\WINDOWS\assembly\GAC_32\mscorlib\2.0.0.0__b77a5c561934e089\sortkey.nlp
C:\WINDOWS\assembly\GAC_32\mscorlib\2.0.0.0__b77a5c561934e089\sorttbls.nlp
C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll
C:\WINDOWS\assembly\GAC_32\System.Transactions\2.0.0.0__b77a5c561934e089\System.Transactions.dll
C:\WINDOWS\assembly\GAC_MSIL\System.Messaging\2.0.0.0__b03f5f7f11d50a3a\System.Messaging.dll
C:\WINDOWS\assembly\GAC_MSIL\System.Runtime.Remoting\2.0.0.0__b77a5c561934e089\System.Runtime.Remoting.dll
C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\indexc3.dat
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\mscorlib\7bffd7ff2009f421fe5d229927588496\mscorlib.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Configuration\ab688d0f9f333ba117832726bfb589c1\System.Configuration.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Data\f04ef00e652a8655a717639e8aeb7b63\System.Data.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Drawing\dcc0244092fe52e6885b50be25ef3b31\System.Drawing.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.EnterpriseSe#\15724a7517f939c9b300f341fb5620b8\System.EnterpriseServices.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.EnterpriseSe#\15724a7517f939c9b300f341fb5620b8\System.EnterpriseServices.Wrapper.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.ServiceProce#\8b000cc703c9d95593b516bf2c2ec316\System.ServiceProcess.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Transactions\26d5bf1f7e700c2c19aa9b1da5519b24\System.Transactions.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\439c466b60614915587c5273eaf0ca7f\System.Windows.Forms.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Xml\a6dbe24cbfe3ab6b318ed3095cc572d8\System.Xml.ni.dll
C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System\08ffa4d388d5f007869aa7651c458e7c\System.ni.dll
C:\WINDOWS\assembly\pubpol1.dat
C:\WINDOWS\Debug\UserMode\ChkAcc.bak
C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\mscorwks.dll
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\CONFIG\machine.config
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe.Config
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Culture.dll
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\diasymreader.dll
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorrc.dll
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\clr.dll
C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
C:\WINDOWS\system32\activeds.dll
C:\WINDOWS\system32\activeds.tlb
C:\WINDOWS\system32\adsldp.dll
C:\WINDOWS\system32\adsldpc.dll
C:\WINDOWS\system32\adsnt.dll
C:\WINDOWS\system32\advapi32.dll
C:\WINDOWS\system32\atl.dll
C:\WINDOWS\system32\clbcatq.dll
C:\WINDOWS\system32\cmd.exe
C:\WINDOWS\system32\comdlg32.dll
C:\WINDOWS\system32\comres.dll
C:\WINDOWS\system32\comsvcs.dll
C:\WINDOWS\system32\credui.dll
C:\WINDOWS\system32\crypt32.dll
C:\WINDOWS\system32\cryptdll.dll
C:\WINDOWS\system32\dbnetlib.dll
C:\WINDOWS\system32\digest.dll
C:\WINDOWS\system32\dnsapi.dll
C:\WINDOWS\system32\dssenh.dll
C:\WINDOWS\system32\gdi32.dll
C:\WINDOWS\system32\hnetcfg.dll
C:\WINDOWS\system32\iphlpapi.dll
C:\WINDOWS\system32\iprop.dll
C:\WINDOWS\system32\kernel32.dll
C:\WINDOWS\system32\l_intl.nls
C:\WINDOWS\system32\mapi32.dll
C:\WINDOWS\system32\mqrt.dll
C:\WINDOWS\system32\mqsec.dll
C:\WINDOWS\system32\msapsspc.dll
C:\WINDOWS\system32\mscoree.dll
C:\WINDOWS\system32\msdart.dll
C:\WINDOWS\system32\msimg32.dll
C:\WINDOWS\system32\msnsspc.dll
C:\WINDOWS\system32\msv1_0.dll
C:\WINDOWS\system32\msvcp60.dll
C:\WINDOWS\system32\msvcp71.dll
C:\WINDOWS\system32\msvcr71.dll
C:\WINDOWS\system32\msvcrt40.dll
C:\WINDOWS\system32\mswsock.dll
C:\WINDOWS\system32\msxml4.dll
C:\WINDOWS\system32\msxml4r.dll
C:\WINDOWS\system32\mtxdm.dll
C:\WINDOWS\system32\nddeapi.dll
C:\WINDOWS\system32\netapi32.dll
C:\WINDOWS\system32\netmsg.dll
C:\WINDOWS\system32\ntdsapi.dll
C:\WINDOWS\system32\ntmarta.dll
C:\WINDOWS\system32\odbc32.dll
C:\WINDOWS\system32\odbccp32.dll
C:\WINDOWS\system32\odbcint.dll
C:\WINDOWS\system32\psapi.dll
C:\WINDOWS\system32\rasadhlp.dll
C:\WINDOWS\system32\riched20.dll
C:\WINDOWS\system32\riched32.dll
C:\WINDOWS\system32\rpcss.dll
C:\WINDOWS\system32\rsaenh.dll
C:\WINDOWS\system32\samlib.dll
C:\WINDOWS\system32\schannel.dll
C:\WINDOWS\system32\security.dll
C:\WINDOWS\system32\setupapi.dll
C:\WINDOWS\system32\shell32.dll
C:\WINDOWS\system32\shfolder.dll
C:\WINDOWS\system32\sqlsrv32.dll
C:\WINDOWS\system32\sqlsrv32.rll
C:\WINDOWS\system32\sqlunirl.dll
C:\WINDOWS\system32\sxs.dll
C:\WINDOWS\system32\urlmon.dll
C:\WINDOWS\system32\user32.dll
C:\WINDOWS\system32\userenv.dll
C:\WINDOWS\system32\uxtheme.dll
C:\WINDOWS\system32\version.dll
C:\WINDOWS\system32\wininet.dll
C:\WINDOWS\system32\winmm.dll
C:\WINDOWS\system32\winrnr.dll
C:\WINDOWS\system32\winspool.drv
C:\WINDOWS\system32\ws03res.dll
C:\WINDOWS\system32\ws2_32.dll
C:\WINDOWS\system32\ws2help.dll
C:\WINDOWS\system32\wshqos.dll
C:\WINDOWS\system32\wshtcpip.dll
C:\WINDOWS\system32\wsock32.dll
C:\WINDOWS\system32\xpsp2res.dll
C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca\msvcm80.dll
C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\mfc80u.dll
C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\mfc80ENU.dll
C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790\SYSTEM.ENTERPRISESERVICES.WRAPPER.DLL
In this instance the user had McAfee VirusScan Enterprise Ver 8.5i on his system.
