| Product(s): | ProjectWise Web View Server | ||
| Version(s): | 08.11.11.111 | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
There was no endpoint listening at net.pipe://localhost/BDC/Services/PWDCConfiguration.svc that could accept the message. this is often caused by an incorrect address or SOAP action. See innerException if present for more details
User gets this message when Performing a Full Crawl of the ProjectWise Full Text Index
In IIS select BDC site and change binding from * to localhost
For the WebServer Host Service change the "log on as" to a different account. There may have been restrictions with the Network Service Account.
ProjectWise Web Server Host Service may not start for the first time right after installation, when ProjectWise Web Server and Web View Server is installed on a Windows Server 2008 Service Pack 2 operating system. Restart the PW Webserver host service.
Make sure the net.pipe listener adapter, net.tcp listener adapter, and the net.tcp port sharing services are running.
Reinstall .NET Framework
