| Product(s): | ProjectWise | ||
| Version(s): | V8 XM Edition | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
ProjectWise Server Modules
Minimum Suggested ProjectWise Integration Server Specifications
| Component | Requirement |
| Processor | Pentium® 700 Mhz (or equivalent) processor or better |
| Memory | 1GB of RAM (2GB RAM or more recommended based upon number of clients) |
| Hard disk | 500 MB of Free hard disk space |
| Operating system | Microsoft Windows 2000 Advanced Server (SP 4 Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows 2000 Server (SP 4 with Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows Server 2003 Enterprise Edition R2 (SP2 or later) Microsoft Windows Server 2003 R2 (SP2 or later) Microsoft Windows Server 2003 Standard x64 R2 (SDP2 or later) - 8.9.4.x and higher Supports 32-bit versions of the above Operating Systems running on 64-bit processors |
| Network | Windows networking configured for the TCP/IP protocol (IPV4 only) |
| Application Pre-requisites | MDAC 2.8 SP1 or higher Microsoft .NET 2.0 Framework SELECT Server XM Edition or higher is required to license ProjectWise V8 XM Edition ProjectWise Orchestration Framework Service and MicroStation V8 XM Edition are pre-requisites if this server will be used to host Document Processors(Thumbnail Extractor, Full Text Extractor, File Properties Extractor) |
| Browser |
Minimum Suggested ProjectWise Web Server Specifications
| Processor | Pentium® 700 MHz (or equivalent) processor or better |
| Operating system | ProjectWise Web Server Components for Web Explorer: Microsoft Windows 2000 Advanced Server (SP 4 with Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows 2000 Server (SP 4 Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows Server 2003 Enterprise Edition R2 (SP2 or later) Microsoft Windows Server 2003 R2 (SP2 or later) Internet Information Server(IIS) 5.0 or 6.0 ProjectWise Web Server Components for Web Parts: Microsoft Windows Server 2003 Enterprise Edition R2 (SP2 or later) Microsoft Windows Server 2003 R2 (SP2 or later) Internet Information Server(IIS) 6.0 Supports 32-bit versions of the above Operating Systems running on 64-bit processors |
| Application Pre-requisites | SELECT Server XM Edition or higher is required to license ProjectWise V8 XM Edition ProjectWise Web Server Components for Web Explorer also requires: Sun Java Runtime Engine 1.5.0_04 ProjectWise Web Server Components for Web Parts also requires: Microsoft .NET 1.1 Framework Windows Sharepoint Services 2.0 (SP2) or 3.0 - 3.0 supported on 8.9.4.x and higher SharePoint Portal Services 2.0 (SP2) Microsoft Office Sharepoint Server 2007 - 8.9.4.x and higher |
Minimum Suggested ProjectWise Caching Server Specifications
| Memory | 512 MB of RAM (1GB RAM or more recommended based upon number of clients) |
| Hard disk | 200 MB of Free hard disk space for install of software Additional free hard disk space for appropriate file storage |
| Operating system | Microsoft Windows 2000 Advanced Server (SP 4 Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows 2000 Server (SP 4 Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows Server 2003 Enterprise Edition R2 (SP2 or later) Microsoft Windows Server 2003 R2 (SP2 or later) Microsoft Windows Server 203 Standard x64 R2 (SP2 or later) - 8.9.4.x and higher Supports 32-bit versions of the above Operating Systems running on 64-bit processors |
| Application Pre-requisites | Microsoft .NET 2.0 Framework SELECT Server XM Edition or higher is required to license ProjectWise V8 XM Edition |
Minimum Suggested ProjectWise Gateway Services Specifications
| Operating system | Microsoft Windows 2000 Advanced Server (SP 4 Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows 2000 Server (SP 4 Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows Server 2003 Enterprise Edition R2 (SP2 or later) Microsoft Windows Server 2003 R2 (SP2 or later) Microsoft Windows® Server 2003 Standard x64 R2 (SP2 or later) - 8.9.4.x and higher Supports 32-bit versions of the above Operating Systems running on 64-bit processors |
| Application Pre-requisites | Microsoft .NET 2.0 Framework |
Minimum Suggested ProjectWise Indexing Service Specifications
| Operating system |
Microsoft Windows 2000 Advanced Server (SP 4 with Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows 2000 Server (SP 4 with Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows Server 2003 Enterprise Edition R2 (SP2 or later) Microsoft Windows Server 2003 R2 (SP2 or later) Microsoft Windows Server 2003 Standard x64 R2 (SP2 or later) - 8.9.4.x and higher
| Application Pre-requisites | MDAC 2.8 SP1 or higher Microsoft Indexing Service enabled Microsoft .NET 1.1 Framework SELECT Server XM Edition or higher is required to license ProjectWise V8 XM Edition ProjectWise Orchestration Framework Service and MicroStation V8 XM Edition are pre-requisites if this server will be used to host Document Processors(Thumbnail Extractor, Full Text Extractor, File Properties Extractor) |
Minimum Suggested ProjectWise Orchestration Framework Services Specifications
| Operating system |
| Application Pre-requisites | MDAC 2.8 SP1 or higher Microsoft .NET 1.1 Framework ProjectWise Orchestration Framework Service and MicroStation V8 XM Edition are pre-requisites if this server will be used to host Document Processors(Thumbnail Extractor, Full Text Extractor, File Properties Extractor) MSDE or Microsoft SQL Server 2000 (SP4 or higher) Microsoft MSMQ must be enabled If installed, Microsoft .NET 1.0 Framework must be at SP3 level |
| Browser |
Minimum Suggested ProjectWise Distribution Services Specifications
| Memory | 1GB of RAM (2GB RAM or more recommended depending on number and schedule of jobs) |
| Operating system |
Microsoft Windows 2000 Advanced Server (SP 4 with Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows 2000 Server (SP 4 with Update Rollup 1 for Microsoft Windows 2000 Service Pack 4) Microsoft Windows Server 2003 Enterprise Edition R2 (SP2 or later) Microsoft Windows Server 2003 R2 (SP2 or later) Microsoft Windows Server 2003 Standard x64 R2 (SP2 or later) - 8.9.4.x and higher Supports 32-bit versions of the above Operating Systems running on 64-bit processors |
| Application Pre-requisites | MDAC 2.8 SP1 or higher Microsoft .NET 1.1 Framework SELECT Server XM Edition or higher is required to license ProjectWise V8 XM Edition ProjectWise Orchestration Framework Service ProjectWise Plot Server V8 XM Edition if renditions are to be created |
Minimum Suggested ProjectWise Automation Services Specifications
| Operating system |
| Application Pre-requisites | MDAC 2.8 SP1 or higher Microsoft .NET 1.1 Framework SELECT Server XM Edition or higher is required to license ProjectWise V8 XM Edition ProjectWise Orchestration Framework Service MicroStation V8 XM Edition |
ProjectWise Explorer Client Workstation
| Memory | 128 MB of RAM (additional RAM may be needed for other desktop applications) |
| Hard disk | 75 MB of Free hard disk space for installation Additional 500 megabytes of free hard disk space is recommended if check/copyout working directories are to be kept on the client computer. Additional space required for installation of Bentley Redline. |
| Operating system |
Microsoft Vista - 8.9.4.x and higher Microsoft Windows XP (SP 2 or later) Microsoft Windows 2000 Professional (SP 4 or later) Microsoft Windows Server 2003 Enterprise Edition R2 (SP2 or later ) Microsoft Windows Server 2003 R2 (SP2 or later) |
| Application Pre-requisites | DirectX9 required for use of VPR viewer |
| Browser | Microsoft Internet Explorer 6.0 or Higher MSXML 3 or higher installed(included with Internet Explorer 6) |
ProjectWise Administrator Client Workstation
Minimum Suggested ProjectWise Administrator Specifications
| Memory | 128 MB of RAM |
| Hard disk | 75 MB of Free hard disk space for installation |
| Operating system |
| Application Pre-requisites | Microsoft .NET 1.1 Framework |
ProjectWise Web Explorer Client Workstation
Minimum Suggested ProjectWise Web Explorer Lite Client Specifications
| Operating system |
Microsoft Vista (ProjectWise Web Parts for SharePoint only, 8.9.4.x and higher ) Microsoft Windows XP (SP 2 or later) Microsoft Windows 2000 (SP 4 or later) Microsoft Windows Server 2003 R2 (SP2 or later) Microsoft Windows Server 2003 R2 Enterprise Edition (SP2 or later) Microsoft Windows Server 2003 R2 Standard x64 (SP2 or later) - 8.9.4.x and higher Supports 32-bit versions of the above Operating Systems running on 64-bit processors |
Supported Databases for use with ProjectWise V8 XM Edition
| Oracle® | Oracle® | Microsoft® | Microsoft® |
| 9.2.0.5 | 10.2.0.2 | SQL Server 2000(SP 4 or later) | SQL Server 2005 |
Oracle ODBC Driver 9.2.0.8
Oracle ODBC Driver 10.1.0.5 Or Oracle ODBC Driver 10.2.0.3 | ODBC Driver 2000.85.1022.00 Or ODBC Driver 2000.85.1117.00 Or ODBC Driver 2000.86.1830.00 | ODBC Driver 2000.86.1830.00 |
Core Application Certification
ProjectWise V8 XM Edition has been tested against the following applications:
| Application | Version |
| MicroStation |
08.09.04.x, 08.09.03.x, 08.05.x, 07.01.04.x |
| PowerDraft |
| Bentley Navigator |
08.09.04.x, 08.09.03.x |
| Bentley Redline |
08.09.04.x |
| ProjectWise Publishing Server |
08.09.04.x |
| ProjectWise InterPlot Server |
08.09.04.x |
| AutoCAD |
2008 (8.9.4.63 and higher), 2007, 2006, 2005, 2004, 2002, 2000i, 2000 |
| Microsoft Office |
2007, 2003, XP(SP2), 2000(SP3) |
| Microsoft Project |
2007, 2003, 2002, 2000 |
| Microsoft Visio |
| Microsoft Outlook |
2007, 2003, XP, 2000(SP3) |
Features or Hardware/Software no longer supported by ProjectWise V8 XM Edition
| Component | Detail: |
| Feature | WebFolders Viecon Synchronization |
| Databases | Oracle 8i Sybase |
| Operating systems | Microsoft Windows NT 4.0 for ProjectWise Explorer/Administrator |
| Applications | Markup Manager Microsoft Office 97 MicroStation/PowerDraft 8.1.x Bentley Redline 8.5.x Lotus Notes(messaging integration still supported) Word Perfect Office |
ProjectWise TechNotes And FAQs
