| | Applies To | | |
| | Product(s): | ProjectWise Explorer, ProjectWise Administrator | |
| | Version(s): | V8i SELECTseries 1 (08.11.07.xx ) | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
The following FAQ asks and answers questions about which client versions can connect to the ProjectWise Integration Server V8i (SELECTseries 1), and which client versions can be installed together on the same computer.
- What clients can I use to connect to ProjectWise Integration Server V8i(SELECTseries 1)?
- ProjectWise Administrator V8i (SELECTseries 1)
- ProjectWise Explorer V8i (SELECTseries 1)
- Can these two (new and old) clients coexist on the same computer?
- ProjectWise Explorer V8i (SELECTseries 1) and ProjectWise Explorer V8i? NO
- ProjectWise Explorer V8i (SELECTseries 1) and ProjectWise Explorer V8 XM Edition? YES
- ProjectWise Explorer V8i (SELECTseries 1) and ProjectWise Explorer 2004 Edition? YES
- ProjectWise Administrator V8i (SELECTseries 1) and ProjectWise Administrator V8i? NO
- ProjectWise Administrator V8i (SELECTseries 1) and ProjectWise Administrator V8 XM Edition? YES
- ProjectWise Administrator V8i (SELECTseries 1) and ProjectWise Administrator 2004 Edition? YES
- ProjectWise Administrator V8i (SELECTseries 1) and ProjectWise Explorer V8i? NO
- ProjectWise Administrator V8i (SELECTseries 1) and ProjectWise Explorer V8 XM Edition? YES
- ProjectWise Administrator V8i (SELECTseries 1) and ProjectWise Explorer 2004 Edition? YES
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
