| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Export | ||
| Date Logged & Current Version | Jan. 2016 10.00.00.10 |
Can AutoPIPE CONNECT 10.00.00.10 and lower export a model to ceasar v6.1 or v7.0?
The following warnings appear in ceasar when importing an AutoPIPE generated CII 5.x file format:
IECHO
There was a failure in the conversion process.
ceasar II
Error processing COORDS section, line 7783
The ceasar file formats are constantly changing with each new release of the program, see WIKI here for current import / export capabilities based on version of AutoPIPE.
Export AutoPIPE model to Caesar II neutral (*.cii)
