| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT | ||
| Area: | Install | ||
| Date Logged & Current Version | June 2019 12.00.00.16 |
How Do I Install Bentley AutoPIPE CONNECT QA v.12.00.00.16 ?.
| Install AutoPIPE CONNECT 12.00.00.16 |
1. This procedure assumes that Licensing Server has already been install and configured for the company, If not please contact your Bentley On-Site Admin or Bentley License group to assist you.
2. User currently logged into the computer must have full Administration rights.
3. Suggest that AutoPIPE CONNECT is installed by accepting all the default settings.
a. Prefer that the application is not installed over a network connection; suggest that the EXE file or CD be on the user's computer before starting the installation.
b. If you have already installed other AutoPIPE versions, using add/remove programs uninstall:
i. all previous versions of AutoPIPE
ii. " PCF to NTL translator
iii. " ADLPipe to NTL translator
iv. " Bentley STRAIT
c. Navigate to the EXE file copied to the computer or from the CD
d. Double click on the "ap12000016en.exe" to start the installation process.
Note: Be patient while the application is installing as it is checking to verify programs already installed, verifying drive space, etc.. there may be periods when it appears nothing is happening. Give the system time. In the event the installation stops a warning / error will be presented. Just follow the prompts and be patient. Highly recommended that all applications are closed during the installation process. On average it will take 6-8 min to install everything.
Finished, AutoPIPE has now been installed, continue...
| Install ATS |
a. Navigate to the "AP_ATS_12000016en.zip" file on the DVD received from the QA manager
( remember - it is not a certified installation if installed from a Downloaded file, ATS application MUST be installed from the QA DVD)
b. Unzip the contents of the file to a suitable folder location of your choosing.
c. Open the following folder location:
\AP_ATS_12000016en \12000016en \product \install
d. Double click on "Setup.exe" to start the installation process
If the program will not install based on the instructions above, please log a Bentley Service Request mentioning this page and include a copy of the Error log displayed
Install any Dependencies as needed,
- OpenPLANT Isometric Manager
- ProjectWise
- etc...
Detailed installation procedures for these other applications can be found on other WIKI pages or readme files.
Before starting AutoPIPE, continue to STEP #3: Set-Up Licensing
Download, Install, and License AutoPIPE CONNECT 12.00.xx.xx and higher
