| Product(s): | AutoPIPE Nozzle |
| Version(s): | ALL; |
| Area: | Warning |
| Date Logged & Current Version | Sept. 2018 08.11.08.33 |
The following message appears when running an analysis in AutoPIPE Nozzle:
Warning Message
Pad width is smaller than 1.65*SQRT(RT) = 989.38mm
as recommended by WRC297 & ASME VIII
OK
OR
Warning Message
Pad width is smaller than 1.65*SQRT(RT) = 162.64mm
Pad width is smaller than SQRT(Rm * Tsheel)/1.285 = 76.71mm
as recommended for elastic beam behavior for the load attenuation method.
OK
Warning Message
where Rm = Mean radius of the shell and T shell = Shell thickness
Pad width is smaller than SQRT(Rm * Tshell)/1.285 = 76.71mm
OK
Why and how to avoid?
If the width of the shell reinforcement (pad, plate, or insert plate) is less than mentioned, then conservatism would require that no credit be taken for the reinforcing material when calculating stress resultants at the junction. See WRC 297, section - A-5 Nozzle Reinforcement where this topic is covered in detailed.
Suggest to make changes to the model such that this warning does not appear.
Note, from WRC297:
Therefore, per the code nomenclature, D = Mean Diameter of the shell. Thus the code equation equations 1.65x √ (RT), variable R would be referring to the mean radius of the shell. The same holds true for Rm, however the nomenclature is clearer to understand, Rm = mean radius.
Outside Dia. (OD) = 2168mm
Thickness (T) = 9.0mm
Mean Dia (D) = OD - T
= 2168 - 9
= 2159 mm
Mean Radius (R or Rm) = D / 2
= 2159 / 2
=1079.5 mm
= 1.65 x SQRT (R x T)
= 1.65 x SQRT (1079.5 x 9.0)
= 162.64 mm
= SQRT(Rm x Tshell) /1.285
= SQRT( 1079.5 x 9.0) /1.285
= 76.71mm
Warnings, Errors, Crashed, Confirm Messages in AutoPIPE Nozzle
