| Folder Navigation Panel - | Navigate your work areas with a folder hierarchy, as you do in ProjectWise Explorer. |
| Global View |
(Requires WSG PW Plugin version 3.3) Users can now access the folder's Global View set in ProjectWise Explorer. |
Users can also get links to saved searches to share with others. | |
| Various defect fixes |
| My Views |
| Columns Enhancement |
Added State, Status, and Workflow to columns |
| Saved View Enhancement |
Show work area properties in saved views (if a work area document is selected and the applied saved view contains a work area property, the view column now displays the value of that work area property) |
| Advanced Search |
Advanced searches now support searching by environment attributes. |
| Saved Search |
Both Global and Personal Saved Searches created in ProjectWise Explorer are accessible and displayed in hierarchical list. |
| Configurable Columns |
You can now configure columns to show environment properties and attributes as needed. |
| Grid Column Resizing |
You can now adjust the width of columns. |
| Views |
(Requires WSG PW Plugin version 3.3) You can now change the view in ProjectWise Web. You can apply existing views created in ProjectWise Explorer, and you can also customize the view by adding or removing property columns to the current view as needed. |
| Filtering |
You can now click in each property column header and enter some text in order to filter the list of items that are displayed in the current folder. |
| Version Display |
The displaying or hiding of versions in the document list is now treated as user preference instead of a global setting. |
| Create Connections |
External Users, without a Bentley account, can now create connections to datasources they have permission to access. |
| Ideas Portal |
You can now provide suggestions or comments about ProjectWise Web by clicking the User Feedback button (upper right corner of the ProjectWise Web window) which takes you to an "Ideas" portal just for ProjectWise Web where you can leave your feedback. |
