Microsoft Teams Integration
Use ProjectWise Teams integration to add tabs with ProjectWise Services (available via connect.bentley.com) into your Teams. The integration supports these services:
Users will have to login using their Bentley or federated credentials to access information within these tabs. All access controls already set up in ProjectWise will be respected.
